Author Topic: Numbers info what year is my cz100  (Read 16875 times)
Offline z50jai
  • Trade Count: (0)
  • Full Member
  • my son on the cz100
« on: January 02, 2014, 08:55:26 AM »
Any one know how to work out the year from the frame number? Under my seat I have numbers 63-12
On the left side front I have the S00#### number. And on the rear of the engine box I have S611.
What do you have?
 Any info on this topics would be great.
Monkey on, Monkey nuts!!!
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
Re: Numbers info what year is my cz100
« Reply #1 on: January 02, 2014, 10:12:24 PM »
go to honda
and get a dating cert
the easy way  ;)
Offline S2tpw
  • Trade Count: (0)
  • Jr. Member
« Reply #2 on: January 04, 2014, 09:25:25 AM »
I have no numbers under my seat, or elsewhere on the frame other than the main one
My frame number is 0079x
And engine number is 643xx
I read somewhere that the engine number related to the year. Your seat number seems to make the most sense though, matched with the engine number we could probably get close.
I have a tax disk for April 66. These are issued annually, so mine was probably first registered in April 64
Hope this helps
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
« Reply #3 on: January 04, 2014, 08:11:03 PM »
thats the frame number
what is on the frame near the head stock
if you have the red tank cz100
if you have the white tank cz100
its hard to find
honda did not put frame numbers on the white tank
so
if you have the red tank job
and a number on the frame near the head stock
you have no problem
and that number on the seat
well that could be a lottery ticket number
Offline z50jai
  • Trade Count: (0)
  • Full Member
« Reply #4 on: January 06, 2014, 05:58:51 AM »
I have email honda Australia and they have informed me that they never imported the cz100 into Australia and they cannot help me verify the year.
Any one know who imported the original cz100s into Australia?
Offline z50jai
  • Trade Count: (0)
  • Full Member
« Reply #5 on: January 06, 2014, 06:20:55 AM »
It's amazing what you find on the net when you look. This may help someone else.
Cz100
Australian Model Information
First Model Year 1963
Earliest Known Frame Number S002XX
Earliest Known Engine Number C100E 638XX
Last Model Year 1966
Latest Known Frame Number S00144XX
Latest Known Engine Number C100E 652XX
The first of the Honda 'Monkey' style bikes to be offered through Honda Dealers in any quantity was the CZ100. Most of these bikes were exported and were not available on the JDM (Japan Domestic Market).
The Australian CZ100's were imported by Bennet and Wood, later known as Bennet Honda.
There were three types of CZ100 manufactured from late 1962 through to 1966.
TYPE 1
Identifying Features
The earliest version of the CZ100 model can be easily identified by its white fuel tank
No speedometer or speedometer drive on the front hub
The front hub on the Type 1 CZ100 is in fact a rear hub casting that has not been machined to accept a drive sprocket
Horn located below the larger, speedo-less headlamp bucket and faces forward
Headlamp bucket ears on the front forks are shorter to suit the different headlamp
Under-seat muffler is retained together by a through bolt and acorn nut assembly
Rounder styled front fender
TYPE 2
Type 2 was the first of the red fuel tank CZ100's
Speedometer fitted to headlight bucket
Speedometer drive and new front hub assembly to suit
Horn moved to below the fuel tank and facing RHS of bike
New smaller headlamp with single filament globe
Longer headlamp bucket ears with extra bolts
Later Type 2's had the one piece muffler with fixed end caps
TYPE 3
Front fender changed to a flatter profile
No extra bolts in the headlamp ears
One piece muffler on all bikes
UK & General Export versions had the same small headlamp as a Type 2. The French and Belgium versions had a larger headlamp and separate speedometer mounted on the handlebars
Australian CZ100 Register
FRAME NUMBER ENGINE NUMBER COMMENTS / LOCATION
1 S0061X C100E-6413X QLD
2 S0066X C100E-6418X National Motor Museum Birdwood
3 S0077X C100E-6430X National motorcycle museum Nabiac
4 S0078X C100E-6430X QLD
5 S0087X C100E-6440X QLD
6 S0087X C100E-6439X QLD
7 - C100E-644XX QLD
8 S0091X C100E-6446X NSW
9 S00115X C100E-6494X VIC
10 S00144X C100E-6498X QLD
11 SOO56X.   C100E-6404X.  QLD.
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
« Reply #6 on: January 06, 2014, 09:16:01 PM »
nice one
did honda stamp a frame number on the white tank cz100 ?
Offline z50jai
  • Trade Count: (0)
  • Full Member
« Reply #7 on: January 07, 2014, 01:28:25 AM »
carnt answer that one as I don't have a white rank cz.
wish I did though.
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
« Reply #8 on: January 10, 2014, 08:24:35 PM »
the white tank frame number
and honda have no info on this
waiting 6 months from honda on this
but ive been given a ref number
if i want to ring HONDA again
ill give them a ring  ;)
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
« Reply #9 on: January 21, 2014, 09:13:48 PM »
had a reply from HONDA japan
the bike is to old
and not on HONDA database
so HONDA cannot help on a HONDA bike
lol
Offline quadrazuma
  • Trade Count: (0)
  • Jr. Member
« Reply #10 on: February 10, 2014, 10:44:27 AM »
Hello guys
My white tank have frame numbers at the front right side
Offline miniHM
  • Trade Count: (0)
  • Jr. Member
« Reply #11 on: February 10, 2014, 03:57:39 PM »
 :o :o :o :o :o :o :o
Offline M50NKE
  • Trade Count: (0)
  • Jr. Member
« Reply #12 on: May 25, 2014, 09:30:25 PM »
does that match your engine number
as dealers stamped the engine number on the frame
so they could be  road reged
Powered by EzPortal
